Rotax Bulletin??
yankee-flyer
OK, Guys, I saw something last week about a new service/safety (??) bulletin for the 912 with serial numbers affected-- now I can't find it-- was I dreaming or....
Wayne 120241/143WM
Safety Bulletin
Wayne, I believe you are refering to SB912-058UL regarding the brittle washer that might break. You can get a copy of it by"googling" on "ROTAX SAFETY BULLETIN WASHER" as I recall none of Van's-supplied Rotax engines are involved and they 'took down' that bulletin on their web site.
JohnF
Post was removed
Wayne,
I posted the Rotax bulletin, and also contacted Vans. They then posted it on their website, but took it down shortly after, as none of the engines they have supplied to builders were affected. I then suggested that the VAF moderators should remove the original post, which they did.
