Rotax 912ULS Throttle Management
Piper J3
I recently bought a flying RV-12 with 50TT. The throttle control is horrible with the carburetor springs pulling toward the open position all the time. I understand this is for safety in case the throttle cable breaks. So my question is... has anyone ever had a cable break? The cable looks pretty stout and the installation is clean with nice large radius bends. Operation is smooth except for the constant spring pressure. The friction knurl knob at the base of the throttle control is barely able to prevent creep. Is there a fix short of buying the vernier control? Does the vernier control really fix the weird throttle management? Last question... are weaker springs used with the vernier setup? Sorry for rambling - my thumb and forefinger are sore from flying.
On a positive note - I can't believe how nice this plane flies. I owned a J3-Cub for 23 years and have ~1200 hrs in type. Basically got into the RV-12 and flew it like hand-in-glove. Really sweet. We're going to have good times together.
Oh, and glad to "meet" all you folks finally.
Piper J3
The springs also maintain tension so that the carburetors remain in synch, but I found the throttle creep a problem, so I found a set of springs at Home Depot that provide smooth operation without creep. I recently flew an SLSA with the new "reduced tension" springs, and they were pretty good. My HD springs are still better.
The original throttle springs are way too strong and make the throttle difficult to operate smoothly. I flew for the first year with springs from my local Ace Hardware store, just strong enough to eventually pull the throttle open should the cable break. Once new "official" throttle springs were available from Van's, I replaced mine. I think the real solution to the throttle issue is to go with the vernier throttle replacement for the -12.
I've not heard of a cable breaking but that doesn't really mean anything. It's a simple safety measure that should be employed to avoid an unnecessary off-field landing in the event of a break.
I don't worry about the cable itself breaking, I worry about that one little nut/bolt that holds the cable to the throttle arm.
I've been in a Rotax 912 powered aircraft when the throttle cable broke on an aborted landing and a go-around. Fortunately, the carbs did go to full throttle. Not an RV12 and it had an inferior throttle setup.
I installed a McFarland in my Rans S6 and it worked flawlessly. No throttle creep and carbs remained balanced.
The addition of a simple "bug-nut" just forward of the throttle cable/lever nut will help address this concern.
I disassembled the friction lock on the standard RV-12 throttle control to see why the lock is so hard to tighten sufficiently to prevent throttle creep. There is a fiber washer that conforms to the 45 degree taper on the knurled friction knob. When the friction knob is wound all the way in it bottoms out without causing sufficient compression of fiber washer. I added a spacer washer behind the tapered fiber washer so now the knurled friction knob can apply good force on the tapper and thus hold the throttle shaft without overly tightening the friction knob. The spacer washer is a black flat sink washer from the hardware store. If I remember correctly, it is 15/32?outside diameter and about 1/8? thickness. You need to open up the inside diameter so it slides on the throttle shaft.
What is the exact HomeDepot spring (and what department) that is being used to replace the factory throttle return spring? HD is a big store.
I don't remember the Home Depot spring part number it's about 2 1/2" long, and I had to cut a few coils off one end. I previously tried some HF springs that did not hold up. Both broke at about 45 hours time in service. These HD springs have been in for about 300 hours and 3 years with no problems.
I had a cable break on me
I have had a cable break on me in a Searey I owned. After the fact it was something that could have been avoided but that does not mean it can not happen again. The screw/nut that holds the cable on the throttle leaver on the carb over time became once piece (corrosion) and aloud the cable become the hinge point and over time broke. My carb was set up to go to ideal and cause my wife and I to do an emergency landing in a field due to unable to maintain level flight on one carb.
Like I said it could have been avoid and I check it each time when I had my other Searey and when I fly in others. But to think the cable could not break is very hard to say and I expect the engine to quit or lose power at any time. I have been flying Rotax engines from the old 277 (Single cylinder) up the Rotax 914. I fly that it is not a mater of if it is going to quit it is when it is going to. I live by that motto flying certified and turbine helicopters too.
