Hi,
commonly here in Europe we use system where water and oil is circulated through same system thus they will have same temperature. This significantly speeds up gettin' temps up. This is standard installation in some planes like Dynamic WT-9 (http://www.czechsportplanes.com/).
So the solution exists to solve issues with Rotax cooling so not using it is IMHO more like user error than system error...![]()
Interesting. I've never heard of / seen such a system here in the US. Normally, if it uses anything, there will be a thermostat on oil and, if you're in a really cold climate, coolant. There's also the $0.25 solution of a strip of metal foil HVAC tape over the top 2" of the oil cooler.Hi,
the c-90 ends up being (if I remember) about 50 pounds heavier installed weight. Dimensionally the rotax is, I'd say 25% smaller.
Harold,
I think the 12 will be available by spring.
I hope you don't think you are too old to
build it, because I want as much company
in our age group as possible. One of my
arguments for building again are the benefits
in mental and physical health it provides.
Don't laugh, 'she who must be obeyed' has
bought into it.
I'll be 71 years young in March,
Tom
Do you use oil thermostats also?
Check out the discussion in following thread-Does anyone have any thoughts on using a turbo?
Does anyone have any thoughts on using a turbo 914 instead of the 912 in the RV-12 ? i SPEND A FAIR mount of my time in the Durango,co area where airport density altitudes are often well above 10,000 ft in the summertime.
Have you checked the price of one lately?![]()
IMHO the extra $11K is not worth the extra 15 HP.
http://www.vansairforce.com/community/showthread.php?p=174408&highlight=RV-12T#post174408
Chase Snodgrass
Presidio, TX
http://flybigbend.com
This AGL altitude was discussed during the preliminary meetings on the light-sport rules, and it was decided that they don't want sport pilots flying above 10,000' regardless.I presume that the faa will finally bend to change their 10,000 ft rule to something more sensible,i.e. 3000 ft above agl. I really don't feel light sport would be an option for me unless there is a more suitable engine for altitude than the current 912.
Yes, this was the primary concern. The whole idea of sport pilot is to require minimum training and very low cockpit loads. The original proposal did include an AGL addition, but it was voted down. Is there a possibility that it could be changed? Certainly. But I wouldn't hold my breath.Mel, what was the rationale behind the 10K ceiling? Need for supplemental oxygen?
I agree with you, but as mentioned, if you set the warm engine idle at 1800 or more, you are seeing 2100 on landing, and you just float for ever. Ok to set for 1500, but run it above that if setting in line, warming up, etc.
John Bender
Yep. The only time I'm at fully closed throttle is during power-off approaches and taxi downwind (the CT will easily pick up a LOT of speed otherwise).I agree with John.
I have found 1600-1650 RPM to be a good idle stop setting for the RV-12.
Then never idle it there.
