wirejock
Rod End Bearings.
Sends a shiver down the spine doesn't it?
The idea of trying to put a bolt through a part, then slipping one of those tiny washers on, then slipping the bearing in without the washer falling off, then somehow slipping another mini washer in place. All while laying upside down folded up like a pretzel using one hand. OMG! The last two days my cuss jar filled up enough to buy my beer for the rest of the year. I actually told Sweetie she doesn't want to come in the shop today.
All the tricks are cool. Fishing line, tape, super glue, washer wrenches, whatever flavor you like. Go for it. Actually, a washer wrench with a piece of tape over the edge of the washer, really worked well. When the washer popped out of the washer wrench, the tape held it in place.
However, a little forward thinking might just save you some heart ache. Just install the rod end bearings before installing the component. Duh!
The side by side control stick weldment for example. There's no reason why those rod end bearings can't be installed while it's being assembled on the bench. Any control rods will just screw right on. The pitch bell crank is another. Add the rod ends before installing it. The rods will screw right on. Same for the aileron rod end bearings on the bellcranks and servos. Uggg. I wish I thought about it a long time ago.
If the bearings are in the way or need to be removed, that's far easier and won't cost a six pack in the cuss jar. They come right out and a magnet will snag any parts that fall.
Enjoy my friends. That's the point, right?
