Need some guidance from those of you who riveted the bottom wing skins by yourself, I have managed to rivet the inbourd skin and the outboardskin as far as the last acess hole but cannot see how to finish the skin in particular the trailing edge/rear spar rivets. I do not seem to have enough reach to hold the bucking bar and the rivet gun, is there some trick to this that I am missing.
I am doing the riveting in the wing jig (i.e vertical) is this how most people did it or did they move the wing to the bench.
Are the MK-319 rivets structural such that I could use them on the spar if I cannot get AN426 rivets set in there.
Thanks for any advice
