Rivet Guns
Ron
Active Member
What air pressures are most using with the Taylor 3X or similar on the different rivets?
rivet pressure
'Borrowed' from this site: http://www.rvproject.com/rivets.html
Hope it helps.
-Jim
Suggested Operating Pressures
As I mentioned, I use different operating air pressures at the rivet gun for various different sizes of rivets and material. I put this table of information together based on my experience. Keep in mind that I use an Avery 3X rivet gun, and that your results may vary (some builders opt for a 2X gun, which may behave very differently). Also, you can vary the duration of driving the rivet to compensate for pressure in many cases. For example, instead of cranking the psi up, you can drive the rivet for a longer period of time. Anyway, here are the "baseline" settings I use for reference:
AN426 Rivets:
Rivet Type Air Pressure Duration
AN426AD3-3 to 3-4 34 psi 1 second
AN426AD3-4.5 to 3.5 37 psi 1 ? seconds
AN426AD3-6 plus 40 psi 1 ? seconds
AN426AD4-4 to 4-5 45 psi 1 second
AN426AD4-6 to 4-9 50 psi 1 ? to 2 seconds
AN470 Rivets:
AN470AD4-4 to 4-5 60 psi 1 second
AN470AD4-6 to 4-7 60 psi 1 ? seconds
AN470AD4-8 to 4-9 75 psi 1 ? seconds
AN470AD4-9 plus 80 psi 1 ? to 2 seconds
