Kahuna
Moderatoring
I had the opportunity to first flight a Subie RV8 last weekend and thought Id give you my impressions. Built and owned by Steve Murray. Chase flown by Bob "Subob" Goodman and Doug Ripley.
THis is a stock bolt on Egg subie 6cyl. with a 3 blade electric weighing in at 1250lbs empty. 2 batteries in the standard rear location provide the ballast.
Firing up there was no question a car engine was running up front. Ive flown other Subie RV's before, but this was my first 6 cylinder and boy it sounded very nice. Instrumentation was straight forward with everything I needed to watch the engine on the GRT EFIS.
Taxiing out, the tail wheel chains were loose providing me with a lousy lead taxi to the run up.
In the runup, I ran through his sophisticated busses, manual and automatic pumps, and generally made sure I was ready to kill the engine and land if needed. She was purring along and the only thing wierd was turning a knob on the panel to adjust the electric prop. It worked so I figured I could live with the knob instead of a lever![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
We went out position and hold with a pretty stiff 60degrees off center cross wind steady at 15 gust 22. Got all my headnods from the wingman and off we went.
Accelleration was less than expected but jockying the cross wind kept me tuned to that mostly. On rotation it was point her into the wind and climb climb climb. Wingman took off 5 second seperation and closed on me easily. I knew I was not climbing great, but was surprised to see them there so quickly, especially since they had passengers. So first climb impressions were lack luster and frankly very disappointing for me. I expected the 200hp 3 blade to really shine here, but she didnt.
Made our first turn and trimed her out to an easy cruise. No need to haul the mail here on this car engine. Breakin not necessary like the lyco's. She flew pretty straight, little right rudder trim needed, but wings holding level. I kept reminding my self that the engine was running by looking at the gages. I mean you could hardly hearn the darn thing. Quiet and smoother than anything I have flown before in pistons. Every minute or 2, it was "man this is freakin smooth. Holy ****." I stuck a penny on the panel and she did not budge. COuld not find anything in the cockpit vibrating or moving. Neat. Like a da m n car. Who'da thunk it?
I toyed with the pumps and the prop. The electric prop is not as responsive as a hydrolic one. Oh well, it still works just fine. Pressed on verifying systems, pitot static, electric, avionics, transponder check, A/P. Everything was working fine. Couple squawks hear and there. Fluid temps on this cool day were pretty high but managable with prop pitch. That is gonna need some work.
Dropped the flight in trail for some airframe testing. His stick was cut an inch low to clear the standard instrument panel. Makes for an incomfortable position and high stick forces. Oh well, it still works. Started smelling a litlle coolant from the maneuvers so it was time to knock that off.
Set up for some photo shoots, then time to land.
Set the flight for up echelon to pitchout. On final it was nip and tuck with the winds but always a fun challenge. Ran out of elevator on the round out, added power, set back down at a higher speed and done.
So what do I think?
This plane is neither fast nor powerful. I do not think it is going to keep up with a 180lyco when she is cleaned up with fairings. Time will tell. Its heavy for sure but I do think this will be a great cruiser with the smooth quiet engine.
End of report.
So what do I think?
End of report.
