TCONROY
My 5 year old IO-360-M1B has some oil weeping from the black rubber oil drain hose under the cylinders. I've tightened the hose clamps a little but it didn't seem to help and the hose still rotates freely, likely causing the leak. Should I just buy new hose or is there an aftermarket replacement that folks have found works better/lasts longer?
