Trying to drop the sump on my io-360b1b after my disaster yesterday of dropping the Pmag clamp through the open mag hole. Have everything out of the way now but trying to disconnect the air intake tubes where the rubber sleeve is and can't get them to budge. They rubber sleeves rotate on the tubes but won't slide either way. Do I have to disconnect them at the cylinder heads?
Haven't had a sump off before so just feeling my way through this.
Erich
Erich
