Buggsy2
Fitting my Pepto-Pink cowls, some engine preservation oil dripped on the inside of the lower cowl. Must have been more than a drop or two, because at this time the oily patch on the inside of the cowl is about 12" x 5". It feels slightly oily, and fingers or a paper towel rubbed on it pick up a bit of excess oil.
How can I clean this sufficiently to seal the entire cowl per Vans instructions (West epoxy diluted with acetone)?
Thanks!
Thanks!
