I have a 35 SMOH IO-360A1A from a Mooney that we be installing on our F4 project. One of the intake tubes has an annoying dent on one of the outside corners. I was thinking of getting some large ball bearings that just barley fit in the inside of tube and welding them to a rod so I can hopefully push the dent out from the inside. I'm at work, so I don't have access to measure them. Does anyone know the inside diameter? Or a better method to remove the dent?
Thank you,
Phil
Thank you,
Phil
