I’m looking for advice on making a removable fiberglass windscreen fairing for my RV-8. Long story short, I want to do the fiberglass work in my basement shop instead of the far away unheated hangar, and I can’t get the plane out of the basement if the windscreen, rollbar or canopy are attached to the airplane. Also, I don’t want to do a removable aluminum fairing.
I have taken the EAA fiberglass course where we built the part of the fairing that bonds the windscreen to the forward top skin, but that is the extent of my experience in this area so I may be missing some things. Here’s how I think I would do it:
- Attach windscreen to roll bar with screws per plans.
- Put mylar packaging tape on the forward fuselage skin and windscreen / canopy where the fairing will overlap.
- Mask the fairing area with electrical tape (over the packaging tape) per the instructions.
- Build the fairing and sand to shape per plans.
- Pull the fairing and tape off the plane and hope that it releases easily.
- Unscrew and remove windscreen, rollbar and canopy once all work is done.
- When ready to attach windscreen permanently, use the Sikaflex method to attach the fairing to the forward skin and windscreen.
