L Lapsley Member Apr 19, 2011 #1 Does anyone know of a source for an internal electrical schematic for the 965-347 regulator?
M Mich48041 Well Known Member Apr 19, 2011 #3 Interesting article That is a very interesting article about Voltage Regulator failure due to heat and the need for cooling unless the loads are light. Joe
Jetguy Well Known Member Apr 19, 2011 #4 Cooling tube! That must be why with the addition of the Light kit and the possibility of using the Max amps Vans had us add a cooling tube off the cylinder plenum.
