Regulator Internal schematic
Interesting article
That is a very interesting article about Voltage Regulator failure due to heat and the need for cooling unless the loads are light.
Joe
Cooling tube!
That must be why with the addition of the Light kit and the possibility of using the Max amps Vans had us add a cooling tube off the cylinder plenum.;)
