regulator cooling
crashley
Hi can someone post a picture of the regulator cooling mod as I have cooked a regulator and dont want to cook the new one
thanks
ashley
Correct, you get the pieces as part of the lighting kit. You could order them separately.
Just considering doing this , and wondering how . Thanks for the info. I don't have lighting,but feel it's a good idea anyway
Dick seiders
hi I made a shroud for the regulator ( copied the one from the lighting kit ) and fitted it with a piece of cooling tube from the front duct and all seems ok now I think that even though vans say you only need it if you fit the lighting kit that it is a good idea for all installations as if your battery gets a bit flat the regulator is going to work flat out till it is charged also my supplier said tempurature is a quick way to destroy a regulator
