N941WR
Legacy Member
Ever since I put the O-360, Sam James Cowl, and cooling plenum on my plane I have been struggling with high CHT's.
The only way I could keep my CHT's below 400* at 75% power is to DUMP fuel into the engine. Even then cylinders two and four were always much hotter than one and three.
While the plane was down for some unrelated maintenance I decided to see if I could locate any possible air leaks. Boy did I ever find some leaks.
The largest leak was where the cylinder baffles for #2 and #4 come together. They had bowed out crating an air scoop which was large enough that you could slide a quarter between the baffles. (See Image below.) The same baffle splice exists between #1 and #3 but the baffles were flat against each other.
The old RTV was removed, the cracks were sealed with fresh RTV, RTV was put on each cylinder head were it mated up to the baffles, and a new bead was added to seal the cooling plenum.
The net result was my CHT's came down 25*F. Problem solved!
Here is a picture of the major leak area:
![Baffle%2520Leak%2520with%2520arrows.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-oQFxM8h8n-0%2FUmHTB-xmcAI%2FAAAAAAAABaQ%2Fof7jjn8VPxY%2Fs490%2FBaffle%252520Leak%252520with%252520arrows.jpg&hash=91f371acede34916554ca556040b6162)
