FasGlas
This is the third Red Cube I've installed in my Lancair.. And this is the third Red Cube that's junk! The wiring is solid, the connections are solid, the cube is behind the baffling mounted level with the wires up. I tried fire shield to see if there was any heat getting to it. I removed them and checked for any debris.. I even changed the RDAC to make sure it's not that. Nothing... Just intermittent - All three. Next flight it might work, next flight it might not. These are junk. I've seen many complaints here about them and I've had it.
