I haven't started my 12 kit yet. I'll be visiting the Van's factory in a few weeks and am requesting to know what 'extra' rivets, parts, etc. you all would recommend that I pick up during the visit. Thanks in advance for your recommendations.
OTHERWISE YOU WILL SPEND AS MUCH TIME LOOKING FOR PARTS AS YOU DO INSTALLING THEM.
Flock is made up of cotton fibers. Micro balloons are tiny glass beads. When you mix flock and resin it's like a rock. Micro balloons and resin is easy to sand into shape, lighter than flock but can chip.
I disagree a bit with Jack.
Open the bags and inventory the parts (hardware) to be sure you have them all. THEN, Every part (like a certain size nutplate) goes in its own compartment. You can get great divided compartment containers cheap at Harbor Freight or similar places. You can put more than one type of hardware in the same compartment as long as you cannot mistake them! (Ok to mix one particular size of nutplates and a certain size washer, for example, in the same bin. But never mix more than one size of nutplate, nut, washer, screw, rivet, etc. in the same bin!)
In subsequent kits, you will be getting additional quantities of the same parts (hardware) you got in previous kits. Inventory them, then add them to the appropriate bin with the other parts. You will have a fair amount of leftover rivets and other things. But not generally leftover AN hardware.
The PLANS NEVER REFER TO THE BAGS!!! YOU DO NOT NEED TO KEEP TRACK OF WHAT BAG HAD WHAT PARTS IN IT!!! The plans simply refer to the parts and hardware by its appropriate designation. Once you insure, from the packing list, that all of the hardware you were supposed to get was there, the hardware goes into the bins and you forget about the bags entirely!
Label each bin (compartment) with the official part number. Not the bag number. At least semi-logically arrange the compartment contents.
Bill H.
I have found the videos from homebuilderhelp.com helpful. Since they were made a few years ago they may not show the latest change,but I still have found them helpful. This is especially true when tyring to determine the orientation of parts. My only caution is to follow the plans when there is a difference
Don MacMillan
