Still inspecting my QB Fuse after finally completing the QB Wing riveting this weekend!
Came across an error that might be easy to miss in your inspection. Check the angle aluminum pieces (F-10102 A & B) running under the F-1046-L longeron at the top of the baggage door. They are supposed to be trimmed to 3/8". Mine were attached without removing the material as called out in step 7 and are the full 3/4". I'm going to try to carefully cut those pieces flush with the top of the baggage door rather than removing ~20+ rivets to cut them on the bandsaw.
Just something to check.
