RVG8tor
I still need to rivet in these anchors and I am concerned that due to the curve of the skin and a flat flush rivet set I am going to get distortion in the skin. I did a search and nothing was found so I am guessing this is a no brainier.
I was also considering back riveting these using the big flat mushroom bucking bar from Avery, I did most of the longeron rivet by back riveting but not the curved parts.
So did most of you use a swivel head flush rivet set? If you used the mushroom bar from Avery to back rivet how did that work.
Thanks for the help
Thanks for the help
