Rear empennage nutplates
joer308
Active Member
Patron
On page 10-20, the aft-most k1000-06 nut plate gets dimpled, but the screw hole didn’t get dimpled.
I read through the instructions, but couldn’t understand what happens?
For the flush mounted inspection cover, the top 2 nut plates are k1000-06 that get countersunk? The other 6 are k1100-06’s? Just checking!
Thanks!
Yes aft most screw hole not dimpled.
Yes, on both inspection plate questions. Top picture is before countersink of the top two inspection plate holes, bottom is after. I dimpled the plate on all holes, and used my hand 3 blade deburr to do the countersink.
