wcalvert
Just tonight I'm helping a builder do some work on his RV-8 QB fuse. There are 15 #8 screws in the lower forward fuselage area (dwg 74, detail B-B) that come from outside the skin through a doubler, with an AN-960 washer and nut on the inside. Most of them are accessed inside the gear tower ... ! The rant is asking why the assemblers didn't install them while they had a chance ?! There's very limited access through the lightning holes, and since this is a QB, no chance to do mods on the towers to allow better access. Anyway, lots of choice words and scraped arms and dropped washers before we came up with a better way.
The solution was to use a short (12") piece of hinge rod (3/32" or so, just fits inside the #8 nut and washer. Bend it into a smooth quarter circle, about 6" radius. Fish the wire into the hole from the screw side, then put the inside end where it's easy to get at. Drop the washer and nut over the rod, then push the rod back out with your finger tip until it gets to it's resting place, with your helper holding some resistance against your push. Hold it there, pinning the nut and washer in alignment with the hole. Pull the rod out, then replace it with the screw. Turn until started, tighten in up.
This technique saved an unbelievable amount of frustration and got all the screws in place in less than an hour, vice half a day.
I imagine this could be useful anywhere you have one of those blind spots where you can't get both fingers on the washer/nut stack.
Cheers
Cheers
