Radio transmit issue
Rayh
RV12 I have a dynon SkyView touch, Garmin GRT 200, stick push to talk button, and Lightspeed Zulu 3 headsets. The problem I am having is when I start to transmit I can hear my transmission in both left and right sides of my headset. After about 5-10 seconds of transmitting, it drops to where I can only hear in one side of my headset. Any ideas of what could cause this?
I had a similar issue w/ Lightspeed headsets in another plane. When first plugged in, I had audio for about 3 seconds, then it faded out. Lightspeed advised me to change the Mono/Stereo setting in the headset and that solved it. I'd give that a try and see if helps your issue.
Thanks, I will try that.
