John,Folks,
in the manual on page 46is-02 the call is to remove the preformed radiator hose. That's fine but is there a trick to this task? I can squeeze the spring clamp but cannot get the hose to budge. Any help would be most appreciated
John
Squeeze and hold the spring clamp open and slide the clamp along the hose so it is clear of the hose fitting. Then grab the hose with your hand and twist and wiggle it back and forth and it should come off.Folks,
John
This is in the RV-12 forum, so I would assume so tooJohn,
If you want useful answers, you need to learn to give more info. I'm assuming you have an RV 12??
I was thinking it would have helped if he had specified which radiator hose. A photo would also help, as then I know how much clearance or lack thereof he has to work with.This is in the RV-12 forum, so I would assume so too![]()
I just mounted my Rotax a couple weeks ago and went through the process of removing that hose. I removed the two coil packs and unplugged another wire connector that allowed some room to work with. A straight slip joint pliers was easy enough to move the clamp off the nipple and then I grabbed the bottom end of the hose to twist and wiggle side to side. It came off easier the I thought.Folks,
John
