I am working to install the Lower Empennage Fairing and have drilled and tapped the holes along the Longeron to 6-32. It then says to use #6 CS screws to attach. Should I be dimpling the Lower Empennage Fairing as its only .025, and then countersinking the fuse skin / longeron, or should I try to counter sink the .025 for a #6 screw the best I can, so that I don't have to do anything to the fuse??
Chris
Chris
