What I’ve done, and you could possibly consider:
. I sanded the inside of the cowl with 80 grit paper.
. Blow off dust with compressed air or vacuum it well with a strong shop vac.
. Wipe down with a clean rag and a solvent, like acetone.
. Paint entire inner surface with bilge paint from your local boat store. (This bilge paint is made to be used on fiberglass, and it is resistant to common boat bilge contaminants like fuel, oil, hydraulic fluids). I used a brush on the first coat to make sure it was forced down into the glass weave/pores. Used a foam roller for the second coat.
. Cover susceptible areas with the stick on aluminum shield sold by Vans. I also put 1/8” fiberfrax under the aluminum shield material in areas where the hot exhaust pipes are close to the cowl.
This has held up very well for 3 1/2 years now, including the bilge paint.
