Postulator
Member
Hello all,
New to VAF. I have a RV6-A with a O-320E2A engine. My IA stated that the prop was not in the proper position to allow for hand propping if needed. I took the prop off to replace the alternator drive belt, explored info regarding proper indexing and found that I cannot index my prop correctly. The master bushing is in the correct position in the crank flange, but none of the four oversized holes are in a position to allow the prop to be horizontal with the engine at #1 TDC. The prop I have was supplied by Van's for this engine. I have not contacted Hartzell or Van's yet, but would like to know an opinion or whether anyone else has noticed this with their engine/prop combination. Thanks in advance.
