Phenomflyer237
Member
I had posted a previous post about my plane not reaching max rated RPM on a 0320 160HP. It would only do 2300WOT. After flying the plane some and installing fine wire plugs- now I get just bumping 2600RPM at WOT around 2000ft MSL in FL.
The prop is 70CMCM6S16-0-78
when I run WOT my prop is just shy of 2600RPM and MP is just shy of 27", IAS is 166kts.
is this dangerous to push the engine that hard? does it indicate over propping or under propping?
for normal cruise i run2350RPM and noticed still running 26.5mp leaned 50ROP i am at 8.7gph running 145Kts indicated does this power setting seem normal
Thanks for any help!
