WileEcoyote75
Member
I recently took my RV-6 to a local aviation paint shop for a full strip, primer, patch work and repaint. The original paint job showed Orange peel, few runs, and in many locations it was starting to flake on the leading edge of the wing. The painter said; over all the plane was in good shape, and that he would fix any trouble spots. Well seven weeks later on a four week job, I was very excited to see my new paint job. The first thing I noticed was orange peel on the cowling? I ask the painter why is there orange peel, and he says that is not the paint, but that is from the gel coat in the Fiberglas? Either way it's unacceptable! He then states that he could not possibly fill all of that, it would add five pounds? I am not an expert, but I would expect the fix should have been proper sanding before applying the new paint. The paint is Sherwin Williams Jet Glo Base Clear. I would like some advice from you guys with experience on fiberglass finishing and painting.
https://lh4.googleusercontent.com/-1rSYUmfyISs/VG0tFAIWaSI/AAAAAAAAACQ/9HII1nmN4Rs/s800/image.jpg
Thanks Chad
Thanks Chad
