polishpilot
I have an IO-320 with a Precision Airmotive fuel servo. I have the Van's 360 bottom cowl. The offset mixture lever interferes with the side of the cowl scoop. I have the kit to make a cut out in the FAB for lever movement and I can also make a new mounting plate that is offset to move the entire FAB to the right. This would not solve the lever situation, however. Should I buy a new "straight" lever to replace the offset? ($165) I have read that I might have to still fabricate a "bulge in the side of the scoop for engine movement. This is an updraft servo. I am open to any suggestions from those who may have had the same issue.
Thanks, Jim
Thanks, Jim
