A fellow RV10 owner has purchased a portable air conditioner that runs of a lithium pack in it’s base. See picture.
The question is - is it ok do put it in the luggage compartment and then cut two 5” holes in the luggage bulkhead for the two exhaust pipes. Then just let the natural circulation draw out the hot air.
Or is it ok to cut a big rectangular hole in the bulkhead (with a frame strengthening it) in order to move it a bit back and let the two outlets just release the hot air into the tail one.
Then one more thought that came up, was terminating the two pipes onto louvre installed on the belly. I am very reluctant to cut big hole on the belly.
I will appreciate expert advice. Thank you.
