I should have also asked: How thick did y'all make your doublers?
Due to my particular set of skills, I have a very wide variety of scrap aluminum. As I've said elsewhere, I run an equal-opportunity shop: Every part I touch has an equal opportunity to become scrap.With whatever scrap you have laying around
Yep, make a doubler, easy, there's a pattern in the box
Just install it inside with the screws, no permanent attachment needed.
I know that many people have had good luck with mounting the GTN 650 GPS antenna under the cowl. I am choosing to follow Garmin's installation requirements for it. I do plan to put the PFD's little GPS antenna under the cowl, though. That is a much nicer place than on top of the glare shield, in my opinion.Have you considered mounting it under the top cowling? I have had good luck with this in a few aircraft
