Poll: WAAS GPS antenna doubler
What was your WAAS GPS antenna doubler solution?
  • No doubler, installed antenna directly to skin
    Votes: 7 18.9%
  • Installed a loose doubler, not permanently attached to skin
    Votes: 5 13.5%
  • Riveted doubler to skin
    Votes: 18 48.6%
  • Glued doubler to skin
    Votes: 0 0.0%
  • Other
    Votes: 7 18.9%
  • Total voters
    37
iamtheari
I'm at that point with my RV-14 where I have to bite the bullet and drill some holes in my perfectly good fuselage top skin. I am wondering what the latest wisdom is on installing a doubler. I am using the GA-35 antenna.
Yep, make a doubler, easy, there's a pattern in the box :)
Just install it inside with the screws, no permanent attachment needed.
With whatever scrap you have laying around :D
Due to my particular set of skills, I have a very wide variety of scrap aluminum. As I've said elsewhere, I run an equal-opportunity shop: Every part I touch has an equal opportunity to become scrap. :)
This made my morning! I have my own aluminum recycling center. It runs the gamut, from primer and paint experiments, to countersink cage calibration coupons, and father-daughter riveting sessions. :D
Doublers are typically the same thickness as the skin or one gauge thicker.
Similar approach:
Have you considered mounting it under the top cowling? I have had good luck with this in a few aircraft
I know that many people have had good luck with mounting the GTN 650 GPS antenna under the cowl. I am choosing to follow Garmin's installation requirements for it. I do plan to put the PFD's little GPS antenna under the cowl, though. That is a much nicer place than on top of the glare shield, in my opinion.
The load from such a low drag antenna is so low that I don't think a doubler is really required.
