Question for the brain trust regarding wiring a two PMag system:
If using an ACS keyswitch, can the P leads of the PMags be switched through the ACS switch as with magnetos with the breaker protected power/test circuit wired to separate momentary contact switches?
Should be simple to wire up and is the first choice. Just want to make sure the keyswitch doesn't interfere with anything.
Or would using toggle switches for P lead and Power/test circuit be the best solution? (As suggested in another thread here?)
![PMag switch.JPG PMag switch.JPG](https://vansairforce.net/data/attachments/12/12704-0df9034b533ec0a98961c8180bfe959f.jpg)
