motodave
VAF,
I'm installing a Sam James plenum on my 7 with a I(O)360, James cowl and using the standard Vans baffles (I know that I need to modify these to adapt) to mount the plenum with screws/nut plates to secure it.
Question I'm not clear on is how high above the engine should it be, i.e. what is the clearance between engine and plenum? Should I just make this as high as possible? And, yes I will be mounting the oil cooler to the baffles at #4.
Appreciate any "experiences"!
