fl9500
Active Member
Hi,
When riveting the front spar with a rivet gun (HS-702 front spar, HS-710 REINF.ANGLE, HS-714 SPLICE ANGLE) and the subsequent drill of a damaged rivet, an error happens. Besides drilled (the first time).
During the subsequent attempt to set right and left of the damaged rivets two relief rivets, a rivet head again been damaged and when I drill out the hole, it gone wrong (the second time).
Is there a chance to Rescue the components or should I order new Parts ? What is the best way to "match" new Parts with the other already drilled, dimpleled and primed Spars and Skins ?
Achim (sorry for the google-translator english)
PS: Will order a pneumatic rivet squeezer now...
![fehler03.jpg](/proxy.php?image=http%3A%2F%2Fweb.dm.fh-hannover.de%2Fjoachim%2Fvans%2Ffehler03.jpg&hash=6ccef6fd5a17039307f403b24f7dc091)
![fehler01.jpg](/proxy.php?image=http%3A%2F%2Fweb.dm.fh-hannover.de%2Fjoachim%2Fvans%2Ffehler01.jpg&hash=95afdb4cc0fe8cc8f9e1d0e4c6ee6643)
![fehler02.jpg](/proxy.php?image=http%3A%2F%2Fweb.dm.fh-hannover.de%2Fjoachim%2Fvans%2Ffehler02.jpg&hash=e671a2f44cea85acc4a9bfadb35edd69)
