This is the position that the plasma units are located on the engine as it arrived from Mattituck;
As you can see, they interfere with the rear baffle, it's not possible to feed the wire directly through the baffle as the plasma units are too close so I either
a). need to move them somewhere else
b). fabricate a recess in the rear baffle
If anyone has come up against this problem or if you have pics of where your plasma bits are located on the engine then I'd appreciate some help.
Martin
![plasmabaffles.jpg](/proxy.php?image=http%3A%2F%2Fimg202.imageshack.us%2Fimg202%2F773%2Fplasmabaffles.jpg&hash=6ef91c0d61b17f0d51f4fa67884923e5)
Martin
