bullojm1
Today on a local flight I noticed my voltage was low. After a quick scan of my panel, I noticed the alternator breaker was popped. I attempted to reset it, but it immediately popped. I decowled the airplane and looked for any loose connections from the alternator back to the battery. None were found. I measured the resistance and it was 0 ohms. I then noticed the breaker was popping when I was on the ground by simply turning on the alt field. At first I suspected a bad breaker, but I noticed other electronics would dim the moment the alt field would be engaged.
Now the story leading up to this event occurring. I recently installed a new pc680 battery 2 days ago. I had two successful flights with the new battery. Today I battled with a hot start and really needed to crank the engine multiple times before it came to life, so the battery was definitely drained more than normal. I can see why the breaker might of popped the first time, due to the inrush of current to replenish the low battery. However, I cannot determine why the alternator constantly trips the breaker even with the engine not running,.
Any ideas?
Any ideas?
