Reposting this on RV-8 forum in hope of confirmation of the 3/4" dimension.
I'm ready to fabricate the pitch servo mount angles from 1x1x0.125 angle stock.
If anyone has those angles (perhaps not yet installed) please confirm these dimensions (extrapolated from 3.5" servo mount holes dimension and 3.8" dimension on drawing). Mainly need confirmation of overall length and bellcrank pivot hole to servo hole distance (0.75").
https://drive.google.com/open?id=1pilqmu3vJk22NMJ5rlbduz2Wh9uKxOk_
No, I don't have servo, I just want to replace existing angles before I rivet on the rear top fuselage skin. Haven't decided on Dynon, Garmin or ... yet.
I already have the rodend bearings, rod, bolts, washers, etc. so not buying the kit.
I want to drill the servo attach holes before I install the angles, so when/if I get the servo I can just bolt it in place.
Finn
Finn
