andreskatz
Member
i have to replace a brake line on my rv-8, found the bottom pipe thread fitting loose, being a 90 degree angle part half a turn goes and hits the brake disk.
What a pain, will have to remove the wheel, the brake disk assembly just to tighten the fitting in the bottom. I was considering dremmeling the **** fitting and removing the elbow and adding an extension to the fitting to allow rotationl Anyone one else having the same problem>?
