Forgive my very chapped fingers
I'm having a really tough time getting the cotter pins through these castle nuts on my rudder pedals. This is NOT a case of the bolt not being long enough, in fact I could probably use another washer to take up space. The issue is that the nut won't go on far enough to fully expose the hole. I've tried different nuts, different bolts - same deal - the hole is about 80% exposed when the nut bottoms out and therefore the pin won't go through.
What should be done in this case? I did try asking Van's support, but they don't understand that the bolt IS long enough - the nut just won't go on far enough before bottoming out to get the hole exposed. You can see in my photo the hole is not round.. but these nuts are already on as far as they'll go.
