Pictures request: RV10 front lap belt endfitting/ancor points
supik
Patron
Please post pictures of your front seatbelt anchor points with the front seat lap belts attached to the original RV10 anchor points. I'm wondering if the endfitting has to be a bent one to avoid the webbing scratching the panel surface when tightened by the bolt..
Spacer
There should really be a bushing in that anchor so that you can tighten the bolt on the bushing while letting the belt end freely rotate...
