Really...so then if there is an accident, then I guess these people don't care about their insurance. (not to mention their safety or the planes) I was wondering how weight and balances were passing in some of these configurations. Problem solved....just raise the gross weight! Good grief...DMThe 1800 is gross weight. A 160 rv9a has a Van's gross weight of 1750, but many builders list their gross at 1800 or even 1850.
did not know that. Do now! Thx dmNothing shady going on here.
The manufacturer of the plane (the builder) can legally establish the gross weight. This is nothing new, done and discussed for decades. Insurance shouldn't be any problem as long as a realistic weight is declared. Weight and balance still need to be calculated using the declared gross weight and if it all falls within range there is no reason to believe insurance will be an issue.
For instance....an RV-6 with a wood prop (as was common when the -6 was introduced) will most likely be limited to 1600lb in order to stay within CG range. But if a constant-speed prop is installed, then 1800lb should be useable, and this is why many RV-6's are registered with this gross weight. There are structural limits if +6G is to be considered, but most RVs will never see 6G.
Since I'm both new to the RV (and experimental) world, I am doing all I can to familiarize myself with my new aircraft. Has anyone developed charts regarding take off roll, clearance of a 50 ft. object as they relate to temp and density altitude. Same goes for landing data. I'm sure you all are familiar with the typical POH charts we all poured over in the certified world. Just curious if any of the (smarter than I) engineering folks have done that.
Should be usable based on ?...if a constant-speed prop is installed, then 1800lb should be useable, and this is why many RV-6's are registered with this gross weight.
Indeed Max G in a -6 at 1600lb is +4.4G, as per the manufacturer. At 1800lb the limits are unknown.There are structural limits if +6G is to be considered, but most RVs will never see 6G.
This will depend, sometimes dramatically, based on engine, prop, empty weights, etc. Every RV is different in this regard. If you just purchased an RV it would probably be prudent to go through a comprehensive test period, both to familiarize yourself with YOUR aircraft and to determine the performance numbers you are looking for. Have fun!Since I'm both new to the RV (and experimental) world, I am doing all I can to familiarize myself with my new aircraft. Has anyone developed charts regarding take off roll, clearance of a 50 ft. object as they relate to temp and density altitude. Same goes for landing data. I'm sure you all are familiar with the typical POH charts we all poured over in the certified world. Just curious if any of the (smarter than I) engineering folks have done that.
Remember, the engine mount was designed to carry a 160HP engine at 6G. Add another 100lb for 180HP plus constant speed, and how much do you de-rate the G-rating at gross? How about at aerobatic gross?
