Dbro172
combing through the thousands of data points from the G3X SD card I grabbed a comparison from todays flight vs. almost a year ago of similar DA and percent power. The data below is are averages from about 300 points each, two separate flights. The difference is last year it had a whirlwind GA and slick mags and now a Catto 3B 67x70, dual pmags and improved cowl saver baffles. Both slightly ROP. Both props top out +/- 161 KTAS @ 2700 RPM @ 8500 DA. It appears cruise is now faster & more efficient. Pmags are set to 0 adv shift and 30.8 max advance. I've enjoyed combing through the data and comparing performance settings
WW/Slicks- Catto 3B/Pmags
OAT- 18- 8
DA- 8155- 8098
MP- 21- 21
RPM- 2551- 2511
%PWR- 65- 65
TAS- 144- 148
FFLow- 8- 7.75
CHT1- 363- 361
CHT2- 374- 361
CHT3- 353- 354
CHT4- 378- 366
EGT1- 1360- 1360
EGT2- 1403- 1401
EGT3- 1443- 1438
EGT4- 1437- 1421
OilT- 171- 160
OilP- 78- 74
OAT- 18- 8
DA- 8155- 8098
MP- 21- 21
RPM- 2551- 2511
%PWR- 65- 65
TAS- 144- 148
FFLow- 8- 7.75
CHT1- 363- 361
CHT2- 374- 361
CHT3- 353- 354
CHT4- 378- 366
EGT1- 1360- 1360
EGT2- 1403- 1401
EGT3- 1443- 1438
EGT4- 1437- 1421
OilT- 171- 160
OilP- 78- 74
