Percent Power Table Entries
Swoda
Active Member
Does anyone have the Percent Power Table Entries for a Lycoming O-320 150 HP? I want to set up my GRT EFIS to display percent power. All I could find are the entries for a 160 HP.
  • Power Table.pdf
Everyone understands that this algorithm, and the input data, are for best power mixture, right? Peak egt or full rich, there’ll be a small overestimate. Well LOP, a more substantial over estimate. e.g., don’t go crazy trying to get it accurate to 3 digits.
Yup. From the App:
Nor the one Van's sells with Lycoming...IO-360-M1B
The -M1B and -M1A (which is in the App) are the same except for the location of the prop governor.
"IO-360-M1A
180 hp (134 kW) at 2700 rpm, Minimum fuel grade 91/96 avgas, compression ratio 8.50:1. Same as the B1E but with a front inlet fuel injector, propeller governor on front of the crankcase and a retard magneto.
IO-360-M1B
180 hp (134 kW) at 2700 rpm, Minimum fuel grade 91/96 avgas, compression ratio 8.50:1. Same as the M1A but with a rear-mounted propeller governor and impulse magneto."
"IO-360-M1A
IO-360-M1B
I know, I was just being facetious. :rolleyes:
