wirejock
Vans Pepto Pink Cowl 1: Wirejock 0
Some days you get the bear. Some days you get mauled to death by the Vans Pepto Pink Cowl
Clearly I messed up. I barely trimmed anything just to get the two seams straight.
Yes, I know the cowl is over the skin but even after trimming flush, that gap ain't closing.
My plan is to layup a scarf joint on each half seam, but not full thickness. That way the two halves can overlap. Then I cut and fit the cowl to the firewall properly and use a laser level to shoot the side seam cut line. Yes, the bird is level both long and lat. Then finish adding glass to the strip to full thickness.
Anyone have a better solution please let me know. Chime in.
![20211013_152410.jpg 20211013_152410.jpg](https://vansairforce.net/data/attachments/10/10111-9914343821004718157d969f38a94168.jpg)
