Karetaker
Howdy Everyone. I am getting ready for first flight and am doing the static RPM checks. I was able to get static RPM up to 2580 - 2600 by adjusting the governor lever arm. (Ran out of travel on the low pitch stop adjustment screw.) I want to tweak it more but I noticed that when I pull the propeller control all the way back, the lever arm is no where near the high pitch stop. My question is, how close do I need the governor lever arm to the high pitch stop? Or, will the RPM get low enough in flight long before the stop is reached?
Another question: when moving the governor lever from stop to stop, how far does the mounting hole for the cable move? (what is the total throw of the arm at the connecting rod hole?) I wonder if my cable needs more travel...
I believe I may have to do a combo of loosening the 6 screws, rotate the cap assembly and re-clock the arm. I want to be sure static RPM is limited by the prop stops and not the governor.
Much obliged.
Much obliged.
