kjelle69
Active Member
I have the Cleveland Wheels and brakes assembly which I understand were standard on older RV4 kits.
My question is what the wheel nut torque should be and how the approach should be here?
Its a cotter pin through this nut so you can only tight the nut in 60º steps and the bearings are conical as you probably know.
