I sure must be missing something in the production acceptance procedures section g5-1.
This is for the Garmin g3x system. It says to disconnect the pitot tubing from the ADAHRS and move the AOA tubing to the pito slot. Easy.
Then it says using a 35cc syringe, push the plunger to 7.5cc and then it says to turn on the EFIS and use the syringe to slowly and carefully push air into the AOA port.
Are they talking that little rivet with the mandril driven out on the underside of the left wing? Seriously. With modeling clay? Modeling clay isn't an adhesive and lining up the vacuum tube with the mandrel hole is problematic. Shoot some air in the and, whoosh, bottle rocket tie.
They're talking about another port, right?
The other problem with the instruction is it says to push the syringe to 7.5cc, THEN turn on the EFIS, THEN slowly push more air until you hit 130 knots. Since I've already pushed it to 7.5, is 7.5 more liters enough to bring it to 130?
I'd like to get that far but the whole modeling clay things isn't working for me in this configuration.
Also, once I disconnect stuff on the ADAHRS, the screen on the G3X changes to show me G Force meter. Why?
Talk me through this.
