I decided to refit and repaint my gear leg intersection fairings, and long story short, the paint grew air bubbles upon drying. I have painted small pieces before and no problems. What might have caused this? Used jet glow products.
This is usually an issue of "out gassing" caused by the primer or undercoating not being fully cured or a solvent not being totally evaporated from the base coating. What was the exact process you used including products and times between them?
Almost forgot, what was the temp when you were painting? Bubbles can happen if your reducer is rated for hotter temps than exist when you use it and you don't give the primer or sealer time to cure completely.
the outside layer drying prior to the base coats and or uncured primers. the solvents are trapped and cause this.. make sure your reducer is the correct temperature and you lay ups are not to thick with adequate flash times between coats but not too long..stay with the manufactures specs on this stuff. if you let it flash too long you have to wait overnight.
